How to Make a Quality Picture Frame
Cutting joints by hand challenges your skills. Charles Mak illustrates the technique of cutting a half-lap mitre joint that gives a rock-solid picture frame.
Charles Mak and his quality picture frame
Don’t be fooled by the simple look of a half-lap mitre. The half-lap mitre may not sound as sexy as a dovetail, but it is by no means an easier joint to cut – even for a skilled dovetailer. It requires the same kind of attention to detail and sawing skills to make as any other taxing joints. Your skills and patience will be rewarded with tight corners and flush joints that are the hallmarks of a well-made frame.
Are you ready for the challenge?
Picture frame exploded view
Components and dimensions of the picture frame
Mitre joinery
Mitred frames are usually toughened up in their corners with some kind of fastener, such as loose splines or brads. When good appearance is also required on the edges, loose tongues or biscuits can be used. A half-lap mitre joint combines the element of visual aesthetic (the mitre) with the strength of a structural joint (half-lap). It gives the frame a conventional-looking mitre joint on the front, with a half-lap on the back (see diagram below).
To help start the saw, you can chisel a triangular nick on the waste side of the line
Try to saw up to the gauge lines, not clear of the lines, so as to keep paring to a minimum
The mitre shooting block is also ideal for trimming or squaring the shoulders
Setting out the joint
I planed all the stock to identical width and thickness, removing all the machine marks in the process. You can cut the halves in either order; I started with the mitred tongues. I also chose the tongues as the stiles as I wanted the shoulder end-grains to be visible on the sides. With a pencil, I first roughly marked the cut lines and waste to be sawn. At the scribing stage, I would knife all the mitre lines with a combination square, and score the rest of the lines with marking gauges. To avoid resetting the stop for separate measurements, I used two marking gauges: one gauge set to the stock’s width (‘the width gauge’), and the other set to half of the stock’s thickness (‘the thickness gauge’).
The pencil marks help prevent unnecessary layout or cutting mistakes
Marking out the mitred tongue
I scribed the mitre line on the tongue piece, starting from the outside corner down to halfway of the inside edge. Then, with the width gauge, I scored a shoulder line around the underside of the tongue piece and edges. Lastly, the thickness gauge was used to mark a centreline along the three edges of the tongue piece. Repeat the same layout steps for all other tongue pieces.
Start with a light stroke, then two heavier strokes, to avoid the first cut following the grain line
Hold the ‘width gauge’ tight against the end to scribe the shoulder line
Use the ‘thickness gauge’ to scribe the centreline around the end and both edges
Marking out the mitred shoulder lap
Next, on the shoulder lap piece, I scored a mitre line from the outside corner ending halfway on the inside edge. To mark the centreline, I simply ran the thickness gauge along the top end and inside edge. Proceed to mark all your other shoulder lap pieces in the same way.
For the rail, the centreline is scored only on the inside edge and end
Cutting the tongue
Cutting is the critical part. For lap joints or tenons, I usually start with the cross cuts, roughly providing a baseline for the vertical cuts. First, I chiselled a shallow channel on the mitre line as a saw guide. With the workpiece held down, I sawed down the work up to the centreline. As in the case of cutting tenons or dovetails, saw to the gauge lines, rather than clear of the lines, as much as you can. I flipped the piece over and sawed halfway down the shoulder line at a right angle. With the work cramped vertically, I started to saw at the far corner, gradually lowering the saw to cut a shallow groove on the end. I then sawed down the vertical gauge line, removing the waste to form the tongue.
Butt the saw blade against the chiselled groove and saw down to the centreline
Chisel a sloping groove on the shoulder line as a saw guide and saw down the line
After sawing from corner to corner, I finished the cut with horizontal strokes
Cutting the should half lap
For the mating shoulder lap piece, I cut the mitre in the same manner, up to the shoulder line. I cramped the work obliquely in the vice when sawing down the vertical line to remove the waste to expose the half lap.
If you need some sawing warm-up, start with the half lap, which is simpler than the tongue to cut
Avoid sawing down two scribed lines at a time or sawing to a line that is out of sight
With the stock pinched in the mitre jig, I trimmed the mitre with a precise finish cut
Rebating and beading
Many find it easier to cut a frame’s decorative elements and rebates when the workpieces are still flat and rectangular. However, I chose to cut the mitre and then bead, as beads cut that way would always meet seamlessly at the corners. I first cut the rebates on the back of the frame with a skew rebate plane. For the stopped rebates on the stiles, I chiselled the last sections after cutting most of the rebates with the plane. A simpler but less elegant approach is to cut through rebates on both the rails and the stiles, and then carefully plug the openings. Finally, I ploughed a round bead on the outside edges.
A through rebate was planed on the rails, while a stopped rebate was cut on the stiles
Assembling and finishing
Mitres can be a hassle to glue up, often requiring the use of speciality cramps or cramping jigs. But for lapped mitre joints, some bar cramps and spring cramps are usually sufficient for getting the job done. I would recommend using a reversible glue such as liquid hide glue, if you usually struggle with a mitre assembly. Put on a few coats of finish of your choice, and, after the finish cures, your frame is ready to receive its glass, mat, artwork, backer board and mounting hardware.
C-cramps and spring cramps kept the faces flush while bar cramps drew the frame together
Framing your treasured family memories or woodworking inspirations is distinctly gratifying when you do it by hand!
Display your favourite print in a handcrafted frame for a change
