Michael T Collins makes a Shaker candle stand
What you will need
- Jack plane
- Smoothing plane
- Block plane
- Compass plane (optional)
- Pair of dividers or compass
- Pair of outside callipers
- Spokeshave (one flat, one convex)
- Draw knife (optional)
- Mortise and marking gauge
- Marking knife
- Mallet
- Bevel chisels 6mm, 13mm, 19mm
- and 25mm
- Combination square
- Lathe (optional)
Wood
For the pedestal one would ideally want to use a solid block of clear straight grained wood, however, I wanted to use up some cherry (Prunus avium) boards, left over from other projects and so opted to laminate four boards together.
Cutting list
- Four – 19 x 125 x 485mm
- Legs – 19 x 90 x 371mm
- Cross brace – 19 x 125 x 350mm
- Pedestal – 90 x 485mm laminated or solid straight grained
Shaker candle stand plan
Alternatives
If you do not have access to a lathe – it is best to not try and mimic the smooth lines of a lathe, but opt instead for a modern angular pedestal. Divide the end into a hexagon. Mark the location of the base and saw down 6mm to create the shoulder – from the end draw a hexagon 6mm smaller, then use a chisel to pare away the waste. Plane the pedestal so that it tapers from the shoulder to about 38mm. The tenon on the end is cut with a saw and a rasp. The legs should also be given a more angular treatment to match.
The Shaker’s furniture reached its pinnacle in the first half of the 19th century, building no frills – utilitarian furniture. Among their works is a collection of small side tables that were typically positioned near chairs, desks and beds. The Shakers did most of their evening work by candlelight and today these side tables are often referred to as candle stands. Some of the original tables can be found in New York’s Metropolitan Museum of Art.
In this article I am going to take you through the steps of making a Shaker candle stand, based on one first made at the Shaker Village in New Lebanon, New York and is currently in the collection at the American Museum in Bath. The stand consists of a 19mm thick by 470mm diameter top with a chamfered lower edge. The stand’s tabletop is attached to the 85mm diameter pedestal by a cross brace. The post’s profile is an elongated wine bottle, with a 6 x 90mm rebate at the bottom to accept the legs held in place with sliding dovetails.
The pedestal
Cutting the sliding dovetail
The top
The top is made from four pieces of quarter sawn stock – this will provide the most stable top. Arrange the pieces for best grain match – alternating the direction of the growth rings will prevent the top from cupping.
The brace
Finishing and assembly
Assembling the legs
This is perhaps the easiest part – simply apply glue to the leading edge of the dovetail groove and slide the leg into position. The glue will be smeared down the length of the groove.
Sanding
Sanding is all about removing the scratches from the previous grit and much like painting, the biggest challenge is to know when to stop. The easiest way to know is to remove all the dust with mineral spirits and look to see if the surface has the ‘touch’ that you want.
Michael T Collins
British-born Michael has been working with wood off and on for 40 years. He moved to New York in 1996 and over the years, has made bespoke furniture, including clocks, inlay work, Adams fireplaces, book cases and reproduction furniture.
Web: www.sawdustandwoodchips.com
Twitter: @sawdustandwood
