Oz Hassan builds a multifunctional piece of furniture
At the end of a tough day, it’s nice to put your feet up. This combination footstool gives you somewhere to park your weary bones, but you also get an occasional table thrown in. The design is a simple box on legs and made almost entirely of solid beech. The cushion sits on top of the lid when used as a footstool and is stored in the box when used as an occasional table. The timber was chosen to match other woods in the room.
Slides
Feet
Base
The lid
13. The lid is made from a beech-veneered MDF board with a trim of solid beech to cover the edges. I would normally attempt to make all components out of solid stock, however, as solid timber changes shape with changes in relative humidity, this is only an option if there is joinery holding the piece together. As the lid is loose, I opted for a stable man-made board. The panel was cut to size on the tablesaw. The trim was prepared from a small length of timber, which was thicknessed to a little over the depth of the panel. It was then cut into strips on the tablesaw. As the strips were to be glued onto the panel, it was important to get as good a finish as possible, so I swapped a general-purpose ripping blade for a fine toothed blade
Stool assembly
Assembling the stool sides and base was trickier than you might think. Because the slots in the sides were stopped, it meant the base couldn’t be slid into position. Instead, the base was inserted into the slots of the two opposite sides with the pins, and then the two tail sides tapped into position. The feet were attached after the finish had been applied.
Changing the design
Sanding
The sides and base were sanded separately before the glue-up. It’s much quicker, easier and the results are much better when the thing is in pieces. I used a random orbital sander starting at 120 grit, and worked my way up to 400.
Glue-up
Clean up and finishing
Variations
The design of this stool is very flexible and can be adapted easily:
- It can be made deeper to offer more storage space.
- The lid can be hinged.
- The sides can be built up, as seen in the original design.
- The legs can be longer, shorter or removed altogether.
PHOTOGRAPHS BY BY OZ HASSAN
