Outdoor Axe Block
Lee Stoffer swings into action to make an axe block in green wood for spoon carving. Photographs by Lee Stoffer
Why you need an axe block
Carving spoons from green wood using hand tools is a great way to hone skills and learn a lot about the way wood behaves. Only a few simple cutting tools are required, the first of which is an axe. Another important accessory that can often be overlooked is a decent chopping block to help with the axe work. I’ve tried various set ups over time and thought it was worth sharing my experiences. In this article, I will show you how to make a practical, portable axe block with some useful features. These will make hewing a spoon blank just a little bit easier. The block I’ll be describing in this article is designed to be used while standing. It incorporates the most important functional features of my trusted old favourite.
What you need for an axe block
Wood
• Log of cherry (Prunus spp.) or ash (Fraxinus excelsior), 200mm diameter x 400mm long.
• Straight hardwood for legs, e.g. ash.
An ash log and cleaved ash legs were used for this project
You will need a section of hardwood log; cherry or ash work well and I usually use a knotty piece that’s no use for anything else. It should be at least 200mm in diameter and 300–400mm long. A larger piece is not a problem, but will be heavier to move around. Some fairly straight, cleavable hardwood for the legs is preferable – in this case I’ll be using ash. This project can be completed using green or seasoned material. I prefer the log to be at least part seasoned, and to have developed a radial crack for a couple of crucial reasons:
  • It is useful for function in the finished block
  • A crack can be avoided when working out positions for the legs.
I’ll be using power tools for this project. These including a drill with low gear for slow speed and maximum torque; an impact driver for attaching and adjusting the leg positioning jig; and some green woodworking tools to cleave and shape the legs.
• Chainsaw
• 18V drill
• 32mm and 30mm auger bits
• Impact driver
• Froe
• Club
• Axe
• Drawknife
Health and Safety
Edge tools and chainsaws are dangerous. Only attempt to use hand or powered cutting tools if you have received appropriate training and have correct PPE (Personal Protection Equipment).
Dimensions
Top and sideways view of an axe block
I started with a log 700mm long for the legs.  The finished legs are actually 620mm long on the finished block pictured and the block log itself is 320mm high. Allowing for the splay and tenon fit, the overall working height of the finished block is 820mm. This will suit a user around 6ft in height. Adjust these dimensions accordingly to suit your preferred working height.
Making the legs
Logs of ash perfect for the axe block legs
First, select and cleave some green ash for the legs.
Rough leg dimensions
I got three leg billets from a 1/8 section of a log that was 400mm diameter by 700mm long.
Axes are ideal for knocking of sizeable chunks of wood along the grain
Knock the sharp edges off each billet with an axe and taper one end down to around 40–45mm diameter, starting the taper 150–200mm from the end of the billet.
I keep a selection of dried timber for various purposes
Use a slice of waste pipe with an internal diameter of approximately 32mm, as a guide to mark out the tenon. This is the size of the auger you’ll use for the mortise. Leave the legs to dry, ideally until the moisture content comes down to under 15%.
Shaving the legs to size
When the legs have dried out, begin final shaping of the tapered tenon. I’m using a drawknife and my shaving horse for this job, but you could use a power tenon cutter or turn the legs on a lathe.
A rough finish gives character!
Shave down until you have tapered tenons around 100mm long and the slice of pipe fits down to about halfway. Rotate the pipe guide on the tenon to leave a witness mark where any high spots need to be removed. Don’t worry if there’s a little end grain checking in your tenons from drying.
Creating long curls gives a more consistent finish
Clean up the rest of the legs with the drawknife to leave a reasonably smooth finish. This will reduce the chance of getting splinters when fitting and removing the legs.
Mortise for the legs
Now we can make the mortises for the legs in the larger log. I’ve made a simple jig from plywood to help with alignment. This consists of an equilateral triangle with a hole in the centre, with another triangle to indicate a splay angle of 20°.
Using a guide ensures accurate results
Loosely fix the jig to the centre of the log and rotate so that any radial cracks are away from the points of the base triangle. Tighten the screw and mark all three points onto the log.
Go steady. Resistant cuts can twist the drill
Drill the first mortise to a depth of around 75mm using a 32mm auger bit. Be sure to fit the side handle on your drill, brace yourself and the log, and take it slowly. If the auger bit jams, the torque generated can easily cause wrist injuries. Use an old bar auger instead if you have one or prefer not to use a power drill!
Check you work as you go
Loosen the screw and rotate the jig until the points align again; lock down and repeat the process for the remaining mortises.
Hand or drill augers. Both work well
Now change to a 30mm bit and deepen the holes by another 25mm.
Fitting the legs
Use a mallet to get them in
Test fit your legs.
Ideally, you want the 30mm section of mortise to bite a little on the very end of the tenon, and the taper to seat gently in the 32mm entrance to the mortise. Achieving a nice fit here by fine tuning the tenons means that each leg can be removed for transport, with a couple of sideways taps and a twist.
If you don’t intend to remove the legs then a tighter fit is fine.
Cut the feet for a level work surface
Stand the block on its feet and check the surface is reasonably level. Swapping or rotating the legs a little can often provide enough adjustment. If not, levelling usually only requires the trimming of one leg. Pack waste material (wood or cardboard) under two legs to level the block, then remove the thickness of the packing material from the third leg.
The main body
Time to profile the top of the log
Now we have a nice solid surface to work on (the top of the block should be just below waist height). A bit of shaping of the surface and the use of a couple of notches will provide an advantage when carving spoon blanks. For one of the notches, we can utilise the radial crack that forms in most logs as they dry out. Cut a second notch to add further functionality.
Only use a chain saw if experienced with them
If you’re not confident using a chainsaw to make these cuts, or don’t have a chainsaw, then a handsaw and chisel can easily be used instead.
A ridge will help to hold work pieces in place
Make a vertical cut first about 40mm deep and 75mm back from the edge of the block, with the natural radial crack positioned between four and five o’clock to the cut (or one and two o’clock if you are left handed). Then cut back into the bottom of the vertical cut from the outside top edge of the log block.
Detailing the hold
Cut in a notch between 20mm and 25mm wide, perpendicular to the first cut, at about 45° off vertical, back towards the centre of the block from the edge.
Large tools can perform intricate tasks with a deft hand
The cuts in the block provide a shelf on which to steady a blank when making stop cuts with a saw. The notches can be used to hold and protect the neck and handle when cutting the shoulders of a spoon.
Finishing off the axe block
Underside of the axe block
I have made several of these axe blocks for teaching, so after initial set up, I colour code and mark the positions for each leg to save confusion when they are broken down for storage or transport.
A highly adapted axe block!
You might want to consider adding a carrying handle: a crooked branch pegged to the main log works well. The top peg can be left long and used to hang a club or a saw, keeping them in easy reach. Some form of retainer for the axe itself is also useful. You can modify the design to suit your own needs. This is my old favourite that has been adapted over time. The log is cherry and is tall enough with legs removed to be used in a seated position.
With the legs fitted, it brings it up to a nice height for using the axe in a standing position, which is my preferred and recommended way of working. And there you have it. A handy axe block. Don’t be surprised if you start taking it with you every time you venture out. These dependable stalwarts making working outside with wood easier, safer and more comfortable. Your tools will probably last longer too!
  1. Hi ,
    The Axe block looks great!
    The only thing I can’t get my head around is the angle of the splay of the legs at 20 degrees?
    Is that correct?
    Kind Regards,
    Ian.
Leave a Reply to Ian Mayhew Cancel reply
