Secret screw joinery
Derek Jones takes a look at the ultimate pocket hole screw for clamp free edge joints
Brush applying wood glue to a mortised timber joint
One of the most fascinating aspects of studying period artefacts comes from unravelling the various techniques used to make them. Form and function are obviously important things to consider when it comes to determining where, when and how a piece was made but are often limited in what they can tell us about the maker. When face to face with a period piece keen observers will typically remove a drawer a few inches from its opening to inspect the dovetails and for a split second maybe even experience a connection with the maker.
And while a neat and tidy example will indicate the maker was an accomplished woodworker, it also tells us that such details were of importance when the piece was made. Joints made with less finesse, on the other hand, might suggest otherwise. Venture a little further, however, and you’ll invariably be rewarded with clues about the tools used during construction and how they were employed.
Throughout the centuries we’ve seen a noticeable difference in the way we treat non-show surfaces such as the underneath of chair seats, for example, or the back face of a door panel. For the most part the finishes to these surfaces were created using hand tools and as such often have the scars to prove it. Rough saw marks and undulating surfaces are not hard to find on pieces as late the mid-19th century and, along with the choice of timber used to make these components, can also be an indicator of age and location.
As far back as the 17th century, Holland was a major source of good quality oak for French and English cabinetmakers. As one of the region’s most prolific and successful trading nations, they did an excellent trade converting logs sourced from Eastern European forests into planks using wind-powered sawmills. The uniform pattern of parallel saw marks survives on the non-show faces of some boards making these timbers easily recognisable.
Looking for clues
There are some interesting details about the construction of this drawer from a late 18th-century chest that indicate not only how it was made but also in which order some of the processes were carried out. The half-lap dovetails between the sides and front for example are reasonably delicate and what are often referred to as a London pattern; a descriptive term like Windsor and French polish that refers more to a process than a specific location. The drawer front is made from pine with a mahogany veneer applied to the front face, which features a cocked bead moulding applied around the edge. This style of moulding became popular at the beginning of the 18th century where previously the style was to add moulding to the aperture of a drawer opening in the form of half-round or double D cross-grain moulding. Since its inception as a popular material for cabinetmakers from around 1730, mahogany has been associated with quality. Sourced initially from Jamaica for ship building and later from Spanish colonies in Central America, the supply chain suffered interruptions from war and taxes driving the cost up, thus cementing its status as a luxury item. The availability of wide boards, something unattainable before, meant that early examples of mahogany furniture often featured a lot of solid components. The convenience of which must have made the production of some parts relatively efficient if plane boards were used, reserving the finest figured ones for conversion into veneer.
Antique wooden chest of drawers with round knobs
A George lll mahogany chest of drawers
It was common practice throughout the 18th and 19th centuries to disguise the use of secondary timbers and cabinetmakers would often colour the visible faces of these woods with a stain or paint that matched the colour of the mahogany, typically a much redder tone than we’re used to seeing now. The pigments used in these paints would have been earth pigments, which, unlike wood, do not fade on exposure to sunlight so one could assume that the original colour of the mahogany was of a similar tone. What’s interesting about this drawer is that the inside face of the pine drawer back has been treated to the same colour wash as the inside face of the drawer front, while the back of the drawer back and bottom boards are left bare. Having used paints and stains myself I know how hard it is to attain a clean edge between finished and unfinished surfaces without a trace of paint appearing on any of the adjacent components. The lack of which on this drawer suggests to me that these parts were pre-finished before final assembly of the drawer. On the subject of finishing, also note that the ends of the pins where they protrude through the drawer side are not polished.
Worn wooden furniture corner with exposed dovetail joints
Fine single kerf or London pattern dovetails
Interior of an old wooden drawer with damaged side panel
The inside of the drawer fronts have been painted to resemble mahogany
Small mouse in corner beneath wooden furniture
The inside face of the back of the drawer has also been painted
Digging a little deeper
As well as the things you can see on period artefacts there are a host of other details that generally only ever reveal themselves to the restorer. This next detail is one that I have only come across a few times and I can think of only two reasons why that should be the case. The first because it’s an uncommon practice, and the second because it’s incredibly effective and therefore rarely seen. The secret screw joint, or slot screw joint as I’ve also known it, challenges a number of the basic fine woodworking principles; namely we don’t generally recognise mechanical fixings between mating components as good practice; I’m thinking pocket hole screws and L brackets. But consider this, suppose you hadn’t been influenced by the last few decades of woodworking snobbery and approached construction as a series of problems that need solving. You’d probably consider this technique as viable and for a number of good reasons. Before we get stuck into recreating the joint let’s go back to those wide boards of mahogany for a moment and consider how you might
edge joint a couple of them to make something like a dining table leaf or counter top. Technically speaking, shooting the edges shouldn’t be much more of a problem than shooting those of narrower boards but clamping the two halves together afterwards could prove difficult. Personally I’ve never agreed with the idea that you can never have too many clamps. For me it suggests that you might not have thought through the construction process thoroughly if you get to the glue-up stage and things are going wrong because you don’t have enough clamps. Better to have a system in place that matches your level of equipment. This joint, by the way, does not require clamps to hold it in place while the glue dries, which I’m sure must have been part of the attraction. Sure, you can rely on a rubbed joint to make the connection but as long or wide boards are harder to handle you might struggle to get an invisible seam along the entire length. Long boards are also much harder to get straight in the first place and then keep them that way, so just as you might consider a dowel or two to help with alignment a hidden screw will do the same job.
The mechanics
The traditional version of this joint works by using the basic principle of a wedge. The wedge in this case being the head on a standard countersunk wood screw. The screw is driven into the edge of one board with around a quarter of its length left above the surface. A typical length for a screw in this application will be somewhere in the region of 40mm (1½in) long so all that’s left above ground will be the part of the screw without a thread. At a corresponding location on the second board a hole is drilled to match the diameter of the screw head, or a fraction bigger, to a depth equal or slightly deeper than the amount of screw that is above ground on the first piece. To one side of this hole a series of smaller holes are drilled to the same depth to enable a slot to be cut wide enough to accept the shank of the screw. Once cleaned out with a small chisel the opening should resemble a keyhole. When the boards are brought together the keyhole is positioned over the screw and the boards allowed to touch as if attempting a rubbed joint. A hammer or mallet is used to tap the boards into horizontal alignment and in so doing causes the screw head to bite into wood above and around the slot and hold the two pieces together. For the final glue-up you take the boards apart by tapping the top board back the other way. Then tighten the screws a little, about a quarter of a turn but this will depend on the pitch of the thread and the timber, and add glue to the mating surfaces before joining the boards together for the rest of eternity.
Hand-cut mortise in hardwood beside woodworking tools
The keyhole slot
Damaged metal hinge embedded in a wooden door frame
Notice where the screw head has gouged a path along the slot
Woodworker checks dovetail joint with marking gauge
Secure the bottom board and tap the top one into position
Combination square measuring brass fitting on wooden board
Set the screws at a uniform depth
Assembling the joint
Accurate drilling is the key to success for this joint as the screws need to be 90° to the face of the board. There’s a little leeway in the other plane (along the edge) by a degree or two but ideally dead straight is best. You could pre-drill a block of wood, attach a fence to one side and use that as a guide perhaps. Or if your drill press has the capacity for wide boards that works too. Marking out is pretty straightforward, just place one board on top of the other and mark the common face with a couple of pencil strokes across the joint. Then roll the top board away and clamp the boards together back to back. Space the screws evenly and make a series of corresponding lines on the face and edge of both boards. In the current configuration you’ll only be able to mark and work from the common face. To avoid any confusion later don’t introduce marks to the other faces. Don’t even be tempted to write ‘back’ on them, it’ll only make you want to write ‘front’ on the other side. Set a marking gauge to half the thickness of the board or thereabouts and put a centre line for the screw on one board and the keyhole slots on the other. The same gauge setting works on both boards as long as they are still clamped together.
For multiple fixings you may want to consider using a plunge router. If you’re using straight cutters this method will require two separate operations, one to bore a hole for the screw head and another to cut a slot. An easier method would be to use a keyhole or T-slot cutter. Keyhole cutters are designed so that they can bore a hole (plunge) and then be moved sideways to create a T-slot. T-slot cutters on the other hand are generally not designed to bore holes as they are used to cut long T-shaped slots after the bulk of material has been removed with a grooving or straight two-flute cutter. As these cutters perform very similar tasks they’re usually grouped together in most tool catalogues so be careful when making your selection. The technique for using a keyhole cutter is to plunge, move the required distance to create the slot and then reverse back to your original plunge location to exit the cut by allowing the cutter to rise up through the original bore hole. If you’re jointing thin boards you might need some help to keep the router upright. You can attach a second fence to the rails or just fix an extension to your single one.
Hands marking a wooden plank with a combination square
For convenience, position the square once and just mark both sides of the rule…
Hands marking wood with a precision measuring gauge
…one for the screw and the other for the end of the slot
Hand planing a clamped hardwood board
Clamp the boards back to back and set your gauge to half the thickness of the board
Hand planes hardwood strip in a woodworking jig
Both centre lines can be marked with a single setting from either side of the stack
Drill bit above a hardwood board with drilled holes
Create a slot with a series of holes along the centre line
Chisel shaping a mortise in a wooden workpiece
Use a thin chisel to clear the waste and create the slot
Keyhole cutters
These cutters are available in various sizes and are made to suit screw sizes 8 to 12 and require only one operation to cut the hole for the screw head and slot. The slot is undercut to create a T-shaped hollow where the screw head will locate when the two pieces are brought together. There seems to be quite a difference in price for what are pretty much the same cutters.
Blue T-slot router bit on a wooden surface
A typical keyhole cutter for use in a plunge router
Keyhole-shaped recess cut into a marked wooden board
This cutter undercuts the slot so you must reverse back to the original point of entry
Choice of glue
On a warm day you could get away with using hide glue straight from the cauldron as long as you’re confident the glue won’t start to gel before you can hammer the boards into place. Running a hot iron over the edges or giving them a blast with a hot air gun before application will give you some extra open time. If you do make your own hide glue from pearls you can improve the workability by substituting approximately one half of the water content for a strong beer. The alcohol works as a whetting agent by reducing the surface tension of the water allowing the glue to flow more easily into the pores of the wood without altering the viscosity of the adhesive. The sugar in the alcohol is also a natural preservative making your glue last longer. The addition of a little salt or urea will render the glue liquid at room temperature. Alternatively, one of the room temperature liquid hide glues such as Titebond Liquid Hide Glue or Old Brown Glue will suffice. You can extend the open time of these glues as well using the above methods or you may find that just warming them in a cup of hot water before you start does the trick. PVA and yellow glues with a low viscosity will also work but choose one with an extended open time if you can. Anything that says fast grab on the label might cause problems. I’d probably steer clear of foaming or expanding glues like polyurethane.
Beer can, glue powder and mixing jug on workbench.
Beer is good for glue
Two wood glues beside sandpaper on a wooden workbench
These hide glues are liquid at room temperature so have a longer open time
Why choose a low-tack adhesive?
Rub joints, i.e. those that come together without the use of clamps, benefit from the use of high-tack adhesives, with hot hide glue being the best. In a rub joint you’ll want to be able to move at least one of the components back and forth until the adhesive takes hold and offers sufficient resistance to pulling them apart. Although there’s a little lateral movement required to bond the components together our lock screw joint is effectively a joint formed under pressure created by the screws, which relies on excess glue being dispersed from the joint to complete the bond. As the amount of travel is limited by the length of the slot and in one direction only, it’s possible for the glue to gel (or tack up) before the screws have had a chance to pull the joint up tight.
Which screws to use
For a period-correct recreation of this joint you’ll need to use old-fashioned steel slotted screws as they work best. The edge of the heads on old style screws are usually quite sharp so they are able to cut into the wood either side of the slot and grip tight when the boards are brought together. Modern wood screws, though easier to find, aren’t nearly as nice and tend to have soft edges around the perimeter of the head making them less efficient at cutting a path into the wood. As they are more likely to be the screws you have to hand it’s worth considering taking a file to the head or passing them over a grinder to sharpen the edge. Just be careful not to obliterate the slot. Pozi, Phillips or square head screws are quite acceptable and there’s no need to clock. Ideally the grain at the edge of the board with the keyhole needs to be running as parallel to the joint as possible to avoid the screw from either following the direction of the grain and lifting it away from the joint or splitting the wood altogether. If this is the case consider undercutting the slot with a small chisel to help steer the screw head in the right direction and tighten the screw by 1⁄16th of a turn at a time until a good fit is achieved.
Yes, it might take a few dry runs to get the perfect fit but it’ll be worth the extra effort. If you have used a keyhole cutter to create a T-slot, modern screws won’t cause you any problems but the bite will be significantly less. An alternative would be to use pan head screws with a flat underside to the head or better still round head screws that incorporate a washer. Self-drilling screws or those where the shank is the same thickness as the screw body between threads are likely to bend if the projection is too high. They can also be very brittle and more likely to snap under load on hard timbers.
Two silver wood screws on a wooden surface
Pan head screws will require the use of the T-slot or keyhole cutter
Two brass-coloured wood screws on a wooden surface
The thicker the shank above the thread the better
Two metal screws on a wooden surface
Screws with an integrated washer are a halfway house solution and work in soft timbers
Pros and cons
As far as cons, it should go without saying that burying metal into wood where it can’t be seen and won’t be expected has its flaws, if not for the installer then most certainly for someone else in the future. Wherever possible consider marking the panel in such a way as to identify the position of the screws.
I noticed a couple of important things while investigating this joint that are worth mentioning. The first is to make the slot longer than you think it needs to be and to stop hitting the top board before it registers at the end of the slot. Use the lines on the face of the boards to determine the correct amount of ravel. I had a couple
of dry runs where the screws bent under the pressure and one incidence where the head sheared off. If you bend a screw on the first dry run and then give it a quarter turn to lower it, it will either be leaning towards or away from the face of the board. In this scenario when the boards are assembled the glue line will be open along one edge and therefore not coming together flat. Secondly, you need to plane perfectly flat mating edges, that means no sprung joints.
And as for the pros, a definite advantage of using this joint is that you won’t need clamps to hold the parts together while the glue dries. In some instances you may even find that the panel is ready to work on straight away or that the joint doesn’t require glue at all.
Glue drips along dark wooden panel on timber frame
The squeeze-out indicates the pull from the screws is sufficient to pull the joint closed
Close-up of rough dark wooden tabletop grain
After cleaning up there’s a faint glue line visible
Close-up of dark stained wooden board with repaired edge
Planed flat there’s no trace of a join
Hands holding glued timber board in workshop
Rock solid and no clamps
