Simon Asks:
How do I prevent tear-out when cutting across the grain?
  1. There are a few methods you can use to reduce or eliminate this. The best is to use a fine tooth saw blade and also you can cut the grain with a knife at exactly the edge of where the cut will be, ensure that the edge of the saw’s blade is aligned with this line and on the waste side to ensure a clean cut.
Leave a Reply to Tony Cancel reply
