Duane Cartwright carves a mythical oak leaf dragon.
The leaf dragon is a mythical creature which can be found in many art forms. It’s a great subject for woodcarving as it can be shaped and designed to fit many different styles of carving. Dragons and foliage in their many forms have been popular carving subjects throughout history and the two have been blended together with varying success. This is my interpretation of a leaf dragon.
Design
I have used oak leaves and acorns in this project, but any leaf shape or species could be used. If designing or altering the provided design it’s worth keeping in mind the overall shape of the design. I used the ’S’ shape for the dragon, but a ‘C’ shape can also work very well. Using the pattern provided there are a couple of options open to how you could carve this design. I have carved it as a shallow bas relief, but this design could easily be carved as a deep relief, or even as a pierced relief by cutting the outline and the inner waste areas with a bandsaw or jigsaw.
As a shallow relief, you could also print and carve the design in reverse and place them in such a way to have two leaf dragons facing each other. This type of design is perfect for placing on a fireplace, cupboard doors or something similar.
What you will need
- No.3, 20mm
- No.3, 12mm
- No.5, 3mm
- No.7, 20mm
- No.7, 6mm
- No.9, 15mm
- No.9, 5mm
- No.11, 3mm
- No.21/2, 8mm fishtail
- 2mm spoon chisel
- Hooked skew
- Small carbide burr
Wood
Basswood (Tilia americana) – 280 x 150 x 25mm
Dragon carving plan
Transferring the design
Once you’ve chosen your piece of timber for the carving, transfer the design onto it by using a 6B carbon stick, rubbing it over the back of the printed design and tracing over it. Or you can just glue the printed design onto your block of wood. With the design in place and once you are happy with how it looks, draw a line around the edge of the panel at about 5mm from the back. This is a guide for the depth of the background of your carving.
PHOTOGRAPHS BY DUANE CARTWRIGHT
